Old 09-21-2015, 04:42 AM   #2
billj18
billj18's Avatar
Another option to consider is to use the same 17mm spacer up front as you have in the rear. I originally installed 7mm front/ 15mm rear spacers on mine (although I'm using bolts, rather than lug nuts), but I thought the front tires were still too "recessed." I changed the fronts to 15mm too, and I like the look much better. No problems with clearance, either.
Bill
BJ's BlackBox -- 2001 Boxster
1997 SAAB 900S Turbo
1980 Maxda RX-7
1974 Fiat 124 Spider
1976 Datsun 260Z
billj18 is offline   Reply With Quote
