Originally Posted by GatorLapis
Hello everyone. I just bought a 2002 Boxster and after going to the alignment shop the range on the rear passengers side is .4 to 0 degrees. That's all. The front was fine -.6 and zero toe both sides. The rear drivers was at -1.8.
Has this happened to anyone else? I noticed the passengers side 2ft long aluminum long brace that attaches by 4 nuts and a bolt had to be installed under pressure when I changed the tranny oil. The car only has 38k miles.
This is probably the source of your problem. The uprights may be out of place. If none of the parts have any impact damage you may be able to correct the problem by loosening & realigning all the parts.
