Originally Posted by JayG
is there a part number for the kit?
Yes.
The part number on the box is 3000 830 601.
But obviously, that is not the correct number.
I believe that's what created the confusion, as they put the wrong sticker on the box.
The parts listed on the box are:
The disk inside the kit is not 1864521143, but 1864000045.
I had to do a lot of research about it, until I figured out that the 2.5 and 2.7 are the same part number (5 speed ) , and for the 3.2 the disk is different.
By the way, on both kits the pressure plate is the same part number.
In realty, the disk for the 5 speed and the 6 speed is the same. The only different is the center hub that has a larger diameter on the 6 speed.
