My Spec Boxster is 2450lbs with several opportunities to lose more weight. I think that I could get to 2200 with some work and an affordable investment. But the path from 2200lbs to less than 1900lbs will be expen$$$ive. Remember, at 1900lbs, you're talking about losing 1/3 of the original weight and there is only so much you can jettison; then you have to start replacing steel with aluminum and aluminum with carbon fiber.
