Suggest you search for a tool called "Engine Ear". Use it to located exact source of noise.Best with an assistant who keeps moving the 'ear' around while you use the headset.
Check motor(engine is Aussie) mount- common failure
Remove panels under engine to do the inspection.
Plan on spending several hours on this.
Need ramps to do a competent job.
