Flaps 10,
Thank you for posting your rebuild. I am in similar situation I had a intermixed due to a cracked head. Have done a teardown of the upper end and am on the fence to do a full rebuild. Have read that the cylinders can oval but can't be bored due to no oversized piston & rings not available. Did compression test and was good other than cracked cylinder. I too am considering the EPS roller bearing fix. How many miles have you gone any negative or positive feedback is appreciated. Thanks
