Old 08-18-2015, 12:32 PM   #1
san rensho
I would not do that. Without the engine locked tat TDC, cams locked ,and the tensioners pulled, the shaft will jump to one side due to valve spring pressure, and could jump time in the process. We have had more than one car flat bedded into the shop after doing exactly what you describe. Bad idea.........
If you are going to remove the flange, you need to go the entire route or risk problems.
My question is, can I just remove the nut at the center of the flange, and then spin and push on the shaft to check for smoothness and play of the IMSB and if removing the nut will allow me to check on the bearing, do I have to lock the cams if I am not disturbing the flange?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
