Is it possible you left the wheel a bit loose? The clicking sound would then be the wheel moving as far as it can out of relation to the hub.
If you are driving forward, does the sound happen once and then not again until you travel in reverse? Or rather will it click each time you apply the brakes while moving forward (without first going in reverse)?
