Old 08-12-2015, 07:14 AM   #11
cas951
For those struggling on removing the clamps below the AOS. See my
post here on this thread. Air/Oil Seperator write up?
Most new AOS comes with a new hose. Just cut the hose and you will have easy access to the two clamps for easy removal.
As for your leak. Check between the transmission and engine. If the leak is there its possibly rms or early signs of IMS bearing failure.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
