Old 08-09-2015, 11:49 AM   #5
particlewave
Originally Posted by embryoguy@mac.com View Post
particle, I pulled it out and it looks very silver clean, i tried filing the contact points like some have suggested and did not work. I'm not sure what a cleaner would do since its so clean looking already? still worth getting before I order one? Is it worth ordering a used one or should I just buy new? Thank you for your thoughts.
Wait...I'm confused
Did you take the switch apart, or just clean the wire connector? The contacts are inside the switch (I wouldn't try to take it apart). You should spray contact cleaner inside it and turn the switch several times to clean.
NOT these contacts on the back.
Spray cleaner INSIDE the switch through any open area (probably best to spray down through gap at shaft).
