Originally Posted by jdlmodelt
Actually, I can just faintly see the digital speedometer and outdoor temperature still displaying and changing while the ignition is on and I can see the speed change in accordance with speed, however, it looks like the backlight has burned out in that center digital display area?
j
This is a simple bulb change. You'll have to pull the cluster out, but that only takes a few minutes. The bulbs are easily accessible from the back of the cluster (assuming that yours is pre-facelift).
