Originally Posted by jdlmodelt
Actually, I can just faintly see the digital speedometer and outdoor temperature still displaying and changing while the ignition is on and I can see the speed change in accordance with speed, however, it looks like the backlight has burned out in that center digital display area?
j
Sounds like you found your problem. You may need to do a little minor surgery to get into the cluster to change out the back lighting.
SportsCarLEDs.com Instrument Panel LEDs Kit for the Porsche ® Carrera 996 & Boxster 986
As a last resort, you could send it to Qmulus to have it repaired (if you don't want to do it yourself). He has done a gauge cluster for me and did an awesome job.
