You'll need some help to do this correctly. Loosen the three attachment bolts on each side of the top and pull up and back on the top. While you're pulling up and back on the top, have your helper retighten the mounting bolts. This should allow the top to fall into place like it did originally. I had to do this when I swapped my '01 top for a '04 top. Took a couple of tries before everything was perfect. Hope this helps.
