Motor is ok
Ok, i have connected a battery to the motor with two wires and the motor is spinning. I have no idea what it could be now.
1) I have changed the double relay with a porsche genuine (Could this new one be faulty)
2) Motor works and drives the roof transmission when a battery is applied to it.
3) The window sense which is on the roof latch, does play up and i have to fiddle with it sometimes to make the windows drop, but when they do , the button for roof still doesn't make the motor move.
What could be the next step?!? Any help would be appreciated.
Something to note, I noticed when looking behind the passenger seat there is a cable that links together with another cable with a plastic connector. There is another plastic connector, with one pin (not the usual two pin you would see in a connector) and no cable plugs it into it? Could there be a missing sensor or something there that a mechanic removed when he took my push rods off??
