Old 07-09-2015, 10:47 PM   #1
Keanu
Need help. Have a solid coolant light and i cant figure it out..
1999 2.5 has a solid coolant light on. Left it on a revved it for 2 min at 3k rpm amd left it on for 10 mim but the temp didnt fluctuate or move at all. Coolant level was normal i added a cup of water and it just spit out through the rear passenger wheel area(assuming its the overflow?). Should i replace the coolant sensor? I just want to get that light off and make sure im not overheating later when i start driving it to work again. Any help is greatly appreciated
When my front end accident occured my coolant light turned on. I assumed my radiator took a hit but it looks totally fine i brought it to my uncles shop he said it appeared okay as well. Is there a sensor or something that might have triggered it? Im gonna fill it up with coolant to see if the light goes away or if it leaks somewhere else
Keanu is offline   Reply With Quote
