Old 07-08-2015, 06:55 PM   #7
Gelbster
Originally Posted by pieter1 View Post
Car cranks but will not start. I verified I have spark, fuel pump relay is latching when ignition is in on position. If I put power direct from the battery to the pump it works. But if I plug the connectors back there is no power to the pump. Any ideas next step is CPS (luckily I have one spare as well as two Cam position sensors)
So why not change the CPS??
"When the CPS fails, I think the ECU 'thinks' the engine is not rotating. Therefore there is no need for any fuel.Therefore the fuel pump relay gets no signal.
CPS is not very expensive. About $90 in USA. The part number for mine(but verify for yours) is:
BOSCH - 0261210204 "
