DMage is talking about the wiring to the Bank 1 Variocam actuator.
A Durametric is Porsche-specific test software and an OBD-II cable that provides the capability to test certain subsystems and components (like the Variocam actuators) along with clear check engine lights (CEL's) from your laptop. Cost is $287 new, sometimes they can be found used in the For Sale section. A bit high priced but worth it if you're going to try to do much DIY work.
http://www.durametric.com/
As DMage suggests, start by checking the Variocam wiring for continuity and disconnect/reconnect the connector to make sure that nothing came loose and that the connector is clean.
This is a good link to read and it contains a .pdf trouble shooting guide from the repair manual:
P1341 error today- First check engine light in 3 years! - Rennlist Discussion Forums. You will have to sign up to see the link and trouble-shooting guide. Sign up is free.
