Old 07-05-2015, 01:57 PM   #14
EJ-Fresno
EJ-Fresno's Avatar
Originally Posted by WillH View Post
After a ride on some more crappy asphalt I've realized that the front are bad now that I can here it with the rear being quiet. Jacked up the front passenger side and placed some wood under the tire in a neutral position then banged around with a rubber mallet. Droplinks are quiet. The front trailing link is the noisy.
I believe I read that the 987 front trailing links are a no-go. Any upgraded part numbers? If not then I'm off to order 996-341-043-06
I have the same problem, now that the rear is quiet
Is it a PITA to change or it's pretty straight forward?
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
