Old 06-28-2015, 12:18 PM   #1
JFP in PA
Originally Posted by amagalla View Post
OK. Thanks Jeff. I got the cam lock in, but now the special tool TDC lock won't slip into the hole. Is it OK to do the bearing change if I lock the engine from the flywheel (without the special locking tool)?
Tony
No, because you will need to remove the flywheel to do either the IMS or RMS. You need to find out why the cam tool will not go in with the crank pin in place.
