Old 06-15-2015, 03:15 PM   #3
steved0x
steved0x's Avatar
Are you a member of renntech.org? There is a DIY in the 996 section for door/window microswitched and what symptoms map to what switch. You have to have an account to see it though. I would check there. If the door lock assembly is bad the window drops when you open the door, but goes right back up when you release because the computer thinks the door is still shut. The interior light may fail to come on as well. If your symptoms don't match that I don't think it is the door lock assembly.
