Old 06-04-2015, 11:06 AM   #11
rfuerst911sc
Originally Posted by katanihouse@shaw.ca View Post
Did yours work fine sometimes or did it not shift into gear at all? Mine would go into gear if I worked the gears starting 6th down. Now after sitting 7 months it worked fine but I never went past 2nd as I just wanted to move it back home and not get stuck out. Will look under console this weekend hopefully. Thank you for your help!!
Mine worked perfect including driving it to work that morning. Came out of work, started it up and put it into reverse. Backed out of my spot and went to catch first gear and nothing. I was stuck in reverse with a limp shifter ( I hate that ! ). Shifter moved all around with no resistance at all. That's because the cable was no longer hooked up.
rfuerst911sc is online now   Reply With Quote
