Air and water are Newtonian Fluids. A Newtonian fluid is any fluid that follow the same characteristics as a solid. Flow and velocity are base on friction and static attraction or a coefficient of viscosity. The calculations say ignore a negative number such as pressure because the value are squared so a negative pressure times itself is a positive value.
