Old 05-07-2015, 09:52 AM   #1
rem503
aos hose failure
I noticed an oil leak recently under the passenger side engine area. It turned out to be the bottom accordion hose had slipped off the bottom engine fitting. There was oil all around and under that area.
I replaced the bottom screw clamp with another screw clamp and tightened it down. It seems to be holding. I'm going to be watching that bottom clamp for a while. I have been battling p1128 and p1130 codes as well. I'm hoping that was one source of a vacuum leak.
rem503 is offline   Reply With Quote
