Thread: IMS Replacement
Old 05-05-2015, 09:07 AM   #10
thstone
Originally Posted by Jedi View Post
They also quoted doing an oil change and replacing the rear main seal, is this necessary or might as well do it while they are in there?
Oil change is expected as they will want to remove the filter and check for metal before installing anything and they might as well change the oil while they have the filter out.
Replacing the RMS is standard practice almost anytime that the trans is out since its a cheap part and an easy replacement.
Last, your clutch should be in good condition with only 25K miles, but be prepared for the shop to suggest changing it as long as everything is apart.
