Old 05-01-2015, 07:46 PM   #11
jsceash
jsceash's Avatar
Are you just a complainer? Did you not read my post as to why I did it this way? I also gave the links on how the installs are done and then posted the parts needed.
Your in a dream world if you think a 986 air box with a high flow filter is going to match the air flow the 987 air box will deliver, even with using the stock 986 MAF housing. My car is so much faster after this intake upgrade I have to get new brakes as I'm hitting the corners at such a higher rate of speed, the stock brakes are not cutting it, even with the "restrictions" and no tune needed.
No I don't live in a dream world. If you have some documented data on your HP gain post it so we can see.
Here is what I've done in five years of tracking a my car starting with the original 2.7 motor. I can say for some time I've run almost every configuration of air intake on track and have hours of data recording to back them up.
In the 2.7 with an smooth 3-1/4" inlet pipe upgrade plenum and 74mm throttle body stock MAF stock air box desnorkled. My recorded improvement is 19-20 HP
The next year I ran a Agency power box with a cone filter a SLIGHT improvement.
The next year I had the 987 box stock MAF. The rest was the same as above. I had "NO" improvement in HP or Torque. But I wasted an entire weekend getting it installed IHAVE NO PROBLEM SAYING IT WAS JERRY RIGGED. I could only get 2 bolts in it was cockeyed high in the front low in the back and towards the motor in the rear.
Using your prices the straight pipe throttle body and plenum would have been $170 without 4-6hours removing the intake injectors and all the other crap.
This is a fact I can say the 987 air box never was installed right until I removed the 2.7 motor to install the 3.2/3.6 conversion. It's flush to the cover now the flange had vibrated against the top spot Brad had previously mentioned and made a flat spot that was nearly through. It was bad enough I bought another one.
