Old 04-23-2015, 10:11 AM   #1
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by BFeller View Post
Pull out the round vent just below the passenger side dash vent. Look at the fan that is inside there. Turn the key on, and see of the fan starts and the noise comes back. If it does - you found the culprit.
yeah i'll give that a try most likely Friday and update.
question: no matter what position i put the vents in, the dash ones always blow air. is that normal? i mean i can set them to windscreen only or foot well only and i still have air coming out from the main dash vents. could that be a sign of the motor not working properly?
not that its a bother..
CrisZenithBlue is offline   Reply With Quote
