Old 04-21-2015, 01:58 PM   #3
Gelbster
San Renso is the whizz at these questions.
It sounds like the low amp circuit from the key to the solenoid is working because of the click sound. Seems like the high amp connection/wiring is defective. In theory -just try to 'jump' the high amp connections on the starter if you have access -to prove the point ?
But that flaky VAG ignition switch is always the prime suspect !
