Old 04-20-2015, 07:22 AM   #2
kk2002s
kk2002s's Avatar
Mine began to whine a year back. Instead of simply replacing, you can take apart. There are (2) sealed bearings (Oh No sealed bearings) inside. They can be re-packed with grease and that stops the whine.
Removal is very straight forward. Check the the (3) mounting bolts. They are Rubber glued to threaded shafts to reduce vibration. I had one un-glue. These (3) mounting bolts should be replaced. - Part #3
Seal Grey
