Here are a few of my thoughts;
Engine sensor - knock sensor, cam position sensor, crank position sensor, etc.
Blocked intake - I had similar symptoms ultimately found to be debris in intake. Take it apart and check everything!
ECU - check the re-map.
Variocam - make sure that the variocam system is operating properly
