Old 04-13-2015, 09:34 PM   #1
mack73
Originally Posted by BoxsterSteve View Post
Your clutch will thank you.
You mean throw out bearing?
Although a worn throw out bearing is arguably cheaper and easier to replace than a main shaft bearing in the transmission....but that's probably not going to go bad.
IMO don't worry about clutch in/out when at a light. Short light, clutch in (also leaves you with a quick getaway if needed, long light in neutral). The throw out bearing would get replaced when you're doing the clutch anyways so it isn't like you'll burn it up first
mack73 is offline   Reply With Quote
