			Just a quick note, I replaced the oil pressure sensor and changed the oil so all is good again as far as the Boxster is concerned.
The best way to reach the sensor is through the front access panel.  You can get a wrench on the sensor at that point.  However, you need to snake your hand in through the top in order to grab the sensor and change it out.
The hardest part of the job was getting ready to do the job.
				2004 Boxster S
