I researched going the other way and it requires.
1. Both carriers, bearings, hubs, rotors and calipers. (same brake pads)
2. Both transmission mounts
3. Both axles and axle bolts
4. Clutch disc and pressure plate.
5. Shift cable set.
6. A transmission
If your going to use a 987.1 must be 987.1 axle, bearing carriers, hubs, rotors calipers and sensors. 987.2 add control arms and links
The overall cost was too much, so I stopped looking.
