Thread: Audi Swap
Old 04-10-2015, 09:31 PM   #12
thstone
Originally Posted by KenDFW View Post
note: If you do not have M12x1.5x70mm (999-072-008-09) 'G' bolt location picture, it would be recommended to order and install
http://www.pelicanparts.com/techarticles/Boxster_Tech/37-TRANS-Drop/images_small/Pic4.jpg The boxster transmission has a stud in the case, whereas the audi does not. G bolt did not come with my car.
It is fairly common for one or more of the transmission bolts not to be re-installed if the trans has been out of the car previously. Many of the Boxster Spec racing cars are running fine with only 4-6 bolts rather than all 8. My car has 5.
I'm not saying that this is a "best practice", so don't run out to the garage and start removing transmission bolts. I'm just saying that this happens so don't be entirely surprised if you find that your car has less than all 8.
