wipers will not turn off
I recently purchased a 2001 Boxster S that had no engine or transmission, and the interior was ruined by rain. I found another 2001 S that had been hit in the rear end, with only 27,000 actual miles on it. Unlike my original Boxster that had been an automatic, this one was a manual. I quite literally removed everything from the donor car. When I say everything, I mean everything... Once I had the car back together the only problem I was having was the wipers would not turn off when the ignition switch was turned on. From this web site, I saw where others were having a similar problem and it was suggested the wiper module might be bad. Since I had the one from my original car (the one I removed and replaced from the donor car) I just swapped them out, and to my relief, the wipers started working perfectly. I appreciate the info I received from this site and hope others will find this remedy will resolve their issue, as well.
Mike
