Old 04-03-2015, 04:17 AM   #2
Bigsmoothlee
Originally Posted by soccerties View Post
Do you have a 2000+ 3.4 996 engine? When they went to E throttle it's possible the injectors changed then.
My visual inspection of the injectors from my '99 2.5 engine and '99 3.4 996 engine indicated they were identical (matching part numbers).
Mine is a 2000, and I converted the mechanical throttle 996 engine to fit my 2000 egas 986. Tiptronic or 996s with traction control had an electronic throttle, early or late.
More than anything, the injectors should match the software version of the ecu.
Bigsmoothlee is offline   Reply With Quote
