Old 03-29-2015, 07:21 AM   #3
jdlmodelt
Originally Posted by soccerties View Post
Last fall I installed a 996 3.4 in my 99 Boxster and asked myself the same question. The injectors on the 2.5 had the exact same part numbers of the injectors that came with the 3.4.
I wound up using the 2.5 fuel rails with the 2.5 fuel injectors and they are working fine so far. I'd suggest you do the same if you want to use the 2.5 fuel rails.
How much work is involved in replacing your 2.5 with a 3.4?
