Old 03-22-2015, 06:12 PM   #1
truegearhead
truegearhead's Avatar
Easy way to change the expansion tank
I tackled the expansion tank replacement this afternoon, and was able to knock it out in about 45 minutes(far from the Pelican 4 hour estimate). I found that if you cut part number 15(see image below) in half you only need to remove one hose in the engine bay which you can remove from the engine bay (so nothing needs to be done under the car).
Stu
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
