Old 03-19-2015, 08:02 AM   #22
Gelbster
Very odd that so many flywheel teeth are so badly bent. The DMF must have been dropped on edge? There would have been major damage to the packaging - and to whatever it hit !
My LuK DMF arrived packed very well.
It would be possible to bend the teeth using a long screwdriver instead of the correct flywheel lock.
Suggest you read this to understand more:
Pelican Technical Article: Boxster Clutch Replacement - 986 / 987
There are some diy flywheel lock Posts.The part has 'comb-like' teeth on it to engage the starter ring teeth and a single bolt hole.
