Old 03-19-2015, 06:08 AM   #3
steved0x
steved0x's Avatar
The reason the oil is routed to the oil filter is that it goes from there through relatively large oil passages to feed the rotating assembly, which balls up quickly at high revs and without oil. Feeding oil back into the heads requires the oil to go though small passages backwards before it sees the rotating assembly, which simply could take too long.[/IMG]
Thank you!
Folks that are running an accusump on the boxster using the sandwich adapter (and not the remote oil filter), what oil filter are you running?
  • Wix 51042 (or equivalent) - combined with a deep sump it probably would not hang down much if any? With no deep sump it looks like it would hang down a little.
  • Some shorter filter, like Wix 51081? Looks to have virtually the same specs as the 51042 but just shorter in height, with a shorter change interval?
  • LN billet oil filter with washable media?
  • Other?
Steve
