Old 03-15-2015, 05:37 PM   #2
Gelbster
Why only above 4000rpm? Suggests something is moving(?) under high centrifugal force? Did you use Loctite on the pressure plate bolts?
Worn clutch guide tube? Rust on splines? Let's hope not !
Clutch-pedal return spring defective/disengaged. Easy
Bleed again ? Easy
