James,
To make sure we give you good suggestions, please tell us exactly where you are measuring the voltage.
You said:
"Problem is the Becker radio has voltage protection and only works below 14.15v and so cuts out continuously"
If you get different voltage readings in various locations ,that may be very useful. If there is an abnormally high resistance in the circuits, that would cause all sorts of aberrant problems. The obvious comparison would be voltage from the alternator VR compared to at the battery cables on the battery. Check battery cable to ground/body connection also?
