Old 02-27-2015, 09:18 AM   #23
Gelbster
Markus,
You are correct
I relied on the Interchange information and physical dimensions.The INA part is very common & has many applications if you go through all the Interchange sources.
Here is the Rock Auto info:
2001 PORSCHE BOXSTER 3.2L H6 : Engine : Valve Lifter
BGA Part # HL6330 {#11321748884} Hydraulic Type; Height: 24mm; Outer Diameter: 33mm; Single Lifter
$8.53 each minus 10% discount but shipping from U.K. s $28+
Here is the interchange info from YoYo:
HL6330,BGA HL6330; Valve Tappet
To date, nobody has chimed in here or on other Forums to say :"Yes, I used that part and it has worked correctly for xx,xxx miles".There may be a reason for that..........?
Gelbster is online now   Reply With Quote
