Old 02-23-2015, 04:40 PM   #3
jsceash
jsceash's Avatar
Well for the curious. I had the 2.7 5 spd flywheel and 3.2 6 spd Flywheel on the floor side by side. All the external measurements where the same. Mounted they set the same distance from the motors machined surface to the face of the flywheel. The Pressure plate aligns on the pins on the flywheel as do all the mounting bolts. I don't know how to measure the resistance in the dampening springs but the 3.2 springs are stiffer, there is more resistance.
