Old 02-16-2015, 05:35 PM   #17
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by PorscheFan5 View Post
Thanks guys. Few more questions:
1. I finally have some time to work on the car today afternoon. I found 2 tensioners - one horizontal on drivers side to the rear of the engine jutting out (1 ring), 2nd on passenger side jutting down (2 rings) - where is the third one (3 rings)?
2. When I turn the crank and get cylinder 1 to the top and crank marks matching for TDC, the locking pin in the tear drop hole in the crank is not going in. Am I missing something? I tried all the three holes, no luck. Before you ask how I know cylinder/piston 1 is at the top; I have taken out all the spark plugs and put in an endoscope in cylinder 1 where I can see the piston coming all the way up and the TDC marks on crank matches with the mark on case. I should be at TDC, correct?
Just want to make sure before I lock the crank on the rear with a plate, lock cams and try to pull the IMS flange.
Once at TDC, there is a counter bored boss in the block under the TDC hole in the crank pulley. Make sure the dowel your using isn't to large in diameter to fit in the counter bore. Alignment between the hole in the pulley and the counter bore in the block has to be precise.
2003 S manual
