Old 02-13-2015, 07:20 PM   #1
steved0x
steved0x's Avatar
Another option, since you are just slightly over the wear limit of 6 on one bank is to do nothing. While you are rightly concerned because the numbers are creeping up, I think you still have some time. Mine are at about 4.8 and 5.4 IIRC but they have been rock steady for the 32k miles I've had the car and I'm certainly doing nothing until it gets much worse, eg, tons of plastic bits in the oil and numbers in the 7 range.
Are you absolutely sure you measured when the car was, hot, fully warmed up, as in driving it moderately hard for an hour? My numbers are way high when the car is not fully warmed up.
Warmed up, yes, but I am not sure about it being hot/driven to an hour. I will try and do that this weekend. I did have about 15-20 minutes on it this last time with a fueling break about halfway in that time period. Good points. Thank you.
