Old 02-10-2015, 05:38 PM   #4
dghii
I have a 2000S that had the same radio, 6 channel amp dash, door and rear parcel speakers.
Your door speakers are considered subwoofers and should be playing along with the fronts (and rears if you had them). The door speakers are not full range so you may have to put your ear down by the speaker to see if they are functional.
Your fader is working correctly. If you added the rear parcel shelf speakers, the fader would fade between the dash and the rear speakers. The doors should always be active as they are actually on a seperate output from your amp.
