Old 02-09-2015, 08:20 AM   #5
BYprodriver
BYprodriver's Avatar
As a general rule M6 bolts into the M96 are 10Nm. But that assumes you chased the threaded hole and cleaned swarf/oil/dirt out.
That is true with the exceptions having the 10.9 grade marking on the head. They are torqued to 10 ft/lbs. Cam-cover, case perimeter, camshaft timing gear bolts are 10.9 & torqued to 10 ft/lbs.
