Originally Posted by RayW
Just put mine back on a couple months ago, don't know if these will help......
I think there is a aluminum bar that attaches to those shock absorber type mounts on both sides of the car under the tail lights. That bar could be drilled for heat passage then painted black so it would not be visible through a mesh screen. That screen could consist of a perimeter of aluminum with a center panel for license mounting. I notice that Ferrari's have a whole fine mesh rear panel, in some cases, where heat easily flows outward. I would keep the horizontal aluminum bumper bar just for a bit of protection since it would be used on the street. More thinking out loud. Thanks for the photos.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
