Old 02-05-2015, 01:05 PM   #24
Meir
1999 base
Meir's Avatar
the most impotent thing, is when you get the job done, crank the engine several times for 10 seconds or so, with the DME relay or the fuel pump fuse removed.
that will get the tensioners filled up with oil before the engine goes on high RPM
