Thread: Locked out!
Old 02-03-2015, 10:34 AM   #11
steved0x
steved0x's Avatar
If the car sits more than 5 days, the remote unlock functionality is disabled and you must use the key to unlock the door. Then you can press the unlock button on the key and it is active again. (I always thought you had to put it in the ignition and turn it to re-activate the remote unlocking)
To the OP, maybe you can insert the key and turn it like you are locking/unlocking the door, and then try the remote again? Even if the unlocking portion is broken maybe it will still activate? (Although I imagine you have probably run through a lot of combinations of turning the key and pressing buttons already)
From the manual: (2000 Model Year)
Ugg I just read this...
Originally Posted by greenheckler View Post
- key wont turn left or right.
